Importing large color palettes into custom style from a text file of RGB values
306
11-02-2025 12:54 AM
AMC
I want to import a custom color palette into ArcGIS Pro as a .stylx
I have over 150 colors exported from Adobe Illustrator into a .csv file with their RGB values split into R, G, and B columns. My goal is to turn that into a usable color style in ArcGIS Pro. Is there a way to do this without having to manually mix each color and save it to my style one by one?
If anyone has a workflow for this, please let me know.
HannahGow
Sorry, I don't have an answer but I just googled a similar thing and this just came up. I hope we can find an answer somewhere
BrennanSmith1
LaNereMason
I uploaded my company color pallet with this workflow, (I did use a .style file to import so I am not sure if this will help. Also there is an add database options for the 'Favorites" right click) Hope this helps!
go to 'insert' pane and in the style section click on 'import style'
add your .style file and press OK
Go to your catalog pane and you should see your .style file
you will right click on 'favorites' in the left hand 'Contents' pane and click ADD.
Insert your .style file again (I dragged and dropped from the file location because it wasn't showing in my search for some reason)
In your 'Favorite' section in your Catalog Pane and right click on your imported Style and click "Add to project"
Your color pallet should now have it's own section in symbology under colors!
