Import custom arcpy modules in Pro 1.4 (from Python addin structure)
7175
11
04-18-2017 05:55 PM
RebeccaStrauch__GISP
I'm trying to test some of my custom tools, written for a ArcCatalog python addin.   This is my first attempt to use Pro, without the convenience and the power we have with ArcCatalog (but hoping the idea: Add Stand Alone Data Catalog Like ArcCatalog to ArcGIS Pro  will still happen so that this isn't as critical a test ....please vote up the idea! ).
I have several blahUtils.py  type scripts to separate/organize my common functions. These are located in my Scripts folder in my addin file structure and I import into my tools/scripts using
from blahUtils import *
from moreBlahUtils import *
# etc...
rather than in a library in the python folder....that is, keep the addin all together.
This structure works well in ArcCatalog running is as an built/installed addin or from the Toolbox/Tool used to create the addin.
Putting aside the differences between Python 2.x and 3.x for the time being, how would I import the utility python scripts within my main tool script?  I have read thru
Importing ArcPy—ArcPy Get Started | ArcGIS Desktop    and
Python migration from 10.x to ArcGIS Pro—ArcPy Get Started | ArcGIS Desktop   (no, I have not run the 2to3 tool yet)
but those seem to refer to fairly standard modules.  I would like to keep my scripts in the folder structure for my toolbox (i.e. the addin structure) if possible.
The error I am getting
  File "\\<server>\c$\Users\<user>\_MyPyAddins\dwcUpdateMasterFGDB\Install\scripts\01-CopyDWCMasterSDEtoFGDB.py", line 47, in <module>
    from ADFGUtils import *
  File "\\<server>\c$\Users\<user>\_MyPyAddins\dwcUpdateMasterFGDB\Install\scripts\ADFGUtils.py", line 134
    self.__dict__ = self"""
SyntaxError: (unicode error) 'unicodeescape' codec can't decode bytes in position 188-189: truncated \UXXXXXXXX escape
Failed to execute (01-CopyDWCMasterSDEtoFGDB).
Is basically telling me it can not find the first custom script from ADFGutils import * I am trying to import.
Any suggestions on where I need to put these and how I would refer to them?  Again, I prefer to keep in the same folder with/near my toolbox.
Thanks.
tagging PythonPython AddIns
curtvprice
Pro does not support Python addins. The only flavor it supports are those built in .NET.
For the purposes of closing this thread, below is one way to add a single custom mod which is stored in same folder as the script that is running.  This is how my python addins are setup, so that is what I am testing.  Posting here in case others are trying to do the same.  I will start another post with this as a starting point, but hopefully to make it a bit more dynamic.  (I will come back and add a link to that once posted.)
This is a cut and paste from a large working tool...if something doesn't make sense, let me know...
import os
import sys
import arcpy
# --->  This is for python 3.5 in Pro 1.4.1
# shows messages for python window or tool
def myMsgs(message):
     arcpy.AddMessage(message)
     print(message)
scriptPath, scriptName = (os.path.dirname(sys.argv[0]), os.path.basename(sys.argv[0]))
scriptPathforVer = (scriptPath.replace("\\", "/"))
arcpy.env.scriptWorkspace = scriptPathforVer
myMsgs("Path {0} exists? {1}\n".format(scriptPathforVer, arcpy.Exists(scriptPathforVer)))
# not sure whether this is still needed....
sys.path.append(scriptPathforVer)
mymod = 'myCustomMod'    # for a mod myCustomMod.py in same folder as this script
import importlib.util
modPath = os.path.join(scriptPathforVer, (mymod + ".py"))
modPath = (modPath.replace("\\", "/"))
myMsgs("modpath {0} exists? {1}".format(modPath, arcpy.Exists(modPath)))
try:
     spec = importlib.util.spec_from_file_location(mymod, modPath)
     # hardcodes the myCustomMod mod name.  Refer to mod is myCustomMod.afunc()
     myCustomMod = importlib.util.module_from_spec(spec)
     spec.loader.exec_module(vars()['myCustomMod'])
     myMsgs("Successfully loaded {0}\n".format(mymod))
except:
     myMsgs("-> Unable to load {0}\n".format(mymod))
# test it with something in the mod, e.g.
#  myCustomMod.afunc()
hope this is helpful to someone.
