Import color color ramps from vector & raster (non Arc Style format) files
1665
03-08-2024 01:25 PM
KeithAddison1
I am trying to make use of the color ramps available on this site:
http://soliton.vm.bytemark.co.uk/pub/cpt-city/index.html
They are available in the following formats:
cpt, c3g, ggr, gpf, inc, map, pg, psp, qgs, sao & svg.
Is there any way to import these into a Pro style files (or by any other means) so I can use them in ArcGIS Pro?
Robert_LeClair
Esri Esteemed Contributor
ArcGIS Pro does support the *.svg format and it appears you can import svgs to a style using this GitHub sample here.
KeithAddison1
The 3.0 version doesn't seem to work with 3.2.2.  Add-in successfully installs, I pick the folder with the svg I want and it makes a new STYLX file, which I add through catalog.  But the color ramp doesn't show up, I check show all.  Is there any way to tell if the STYLX actually contains anything besides attempting to load it?
Robert_LeClair
One way to check if anything is contained in the new *.stylx file, you can open the Catalog View from the View core tab, go to the Styles folder, click the newly added style file and you'll see all the Style Classes (points, polygons, color schemes and such).  Is anything there?
KeithAddison1
There is, it picked it up as a point symbol.  Here is what the svg file looks like when opened in AI
I used the import point symbol to see what exactly it picked up, here's the point symbol it grabbed:
Right now I'm fumbling around in AI seeing if I can get rid of the white space & border since that seems to be confusing things.
