Implementing Geocodio API in ArcGIS Pro
1061
12-16-2024 01:10 PM
AveryDurham1
HI,
Does anyone have any experience implementing the Geocodio API in ArcGIS Pro? My end goal is to have a python tool that I can use to geocode a table, which is then put into our standard format and inserted into our database.
I am having trouble first because the python package I want to use to access the geocodio API is not easily installed in ArcGIS because I had to use PIP rather than conda. I am having other problems with it recognizing the modules now that it is installed.
Before I get too far trying to do it my own way, I wanted to see if anyone else has ever tried to integrate the geocodio API? What problems and workarounds did you come up with? It is possible that I am just inexperienced and there is an easier way to automate using the API than a python tool in ArcGIS Pro. I am still in the early exploration phase so I am open to suggestions!
Thanks
Tags (3)
ShanaBritt
Have you considered looking into the ArcPy Geocoding Module? https://pro.arcgis.com/en/pro-app/latest/arcpy/geocoding/what-is-the-geocoding-module.htm
