I only want the selected feature highlighted
3061
08-06-2021 07:02 PM
JamesMcAllister1
In ArcGIS Pro, is there a way you can select a feature in a feature class and only have the selected feature highlighted? I don't want to see the other features.
TimOrmsby
Hi Tatjana, you can make a selection layer from your selected feature.
  1. Select the feature of interest in your layer.
  2. In the Contents pane, right-click the layer, point to Selection, choose Make Layer From Selected Features.
  3. Turn off your original layer.
Now you have a layer pointing to the same data but displaying only the feature of interest.
Alternatively, make a definition query on your layer.
  1. Select the feature of interest.
  2. Get its unique identifier (like OBJECTID) from the attribute table or pop-up.
  3. Open the layer properties for your layer. Click the Definition Query side tab.
  4. Construct a query where OBJECTID = 1 (whatever the value of the feature is)
  5. Click OK.
This will hide the other features in the layer without creating a new layer.
DanPatterson
MVP Esteemed Contributor
Not seeing one
Selection options—ArcGIS Pro | Documentation
but with some trickery
Image on the left... symbology, single symbol, color red.
Image on the left... symbology, single symbol, color white.
... sort of retired...
TimOrmsby
  5. Click OK.
JamesMcAllister1
Thank you! That's helpful.
TimOrmsby
one more option: set a display filter. Similar to a definition query in its visual effect, but doesn't change the attribute table display or field calculations/stats/etc. Those operations still work on all features in the layer, whereas a definition query excludes them.
