I'm looking for the National Land Cover Data set (NLCD) that is not an Image.
2539
6
06-03-2020 08:38 AM
VincentRobinson
I'm looking the National Land Cover Data set  (NLCD) that is not an Image service but a dynamic shape file, can someone let me know where I can find this?
JoeBorgione
What is a dynamic shape file?
VincentRobinson
A format in which I can interact with, export ,view tables and ect.
JoeBorgione
Okay, a feature service, probably a polygon feature service most likely derived from the imagery.
Katie_Clark
You can also look into creating the data yourself from the raster layer with the Raster to Polygon tool.
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
VincentRobinson
Thanks I will try it.
George_Thompson
Esri Notable Contributor
Take a look here: Multi-Resolution Land Characteristics (MRLC) Consortium | Multi-Resolution Land Characteristics (MRL...  it look like you can download it there as an image then convert it.
--- George T.
