I have a question about "Contour Placement" of labels in Pro
3823
11
10-30-2017 08:35 AM
SeanSummers_CC
I have a contour feature in my ArcGIS Pro project.  When I turn on the labels for the elevation (double), they seem to label fine for all of the different label placement options except for "Contour Placement".  I can scroll through all the placement options such as "Basic Line", "European Streets", "North American Streets", etc.. and watch the labels change position, but as soon as I choose the "Contour Placement" they just don't appear.  I have the "View Unplaced" option checked and nothing shows up.  I have tried different options within the placement control pane such as Uphill Alignment, Page Alignment, Ladders and nothing seems to work.  I guess my question is does anybody else have this problem? Is this a bug?  Am I doing something silly?  Thanks for any feedback.
Tags (3)
WendyHarrison
Hi Nicholas,
This wouldn't be a conflict between the different Maplex labeling styles.  It is probably due to the municipal boundaries layer having a high weight set to it.  Which would also explain why adding it in again would fix the issue as the weight would be reset to 0.  do you have a copy of the old project where you could check the weights?
thanks
Wendy
NicholasBarger
ESRI tech support told me this was a bug that has been addressed in ArcGIS Pro 2.3.
However, yes the workaround was to drop the interior weight of the boundary file to 0 and then the contours showed up.
