I have a question about "Contour Placement" of labels in Pro
3817
11
10-30-2017 08:35 AM
SeanSummers_CC
I have a contour feature in my ArcGIS Pro project.  When I turn on the labels for the elevation (double), they seem to label fine for all of the different label placement options except for "Contour Placement".  I can scroll through all the placement options such as "Basic Line", "European Streets", "North American Streets", etc.. and watch the labels change position, but as soon as I choose the "Contour Placement" they just don't appear.  I have the "View Unplaced" option checked and nothing shows up.  I have tried different options within the placement control pane such as Uphill Alignment, Page Alignment, Ladders and nothing seems to work.  I guess my question is does anybody else have this problem? Is this a bug?  Am I doing something silly?  Thanks for any feedback.
Tags (3)
SeanSummers_CC
It appears that everything is working correctly now.  I'm guessing because of 2.1.1?
SeanSummers_CC
MichaelVolz
Esteemed Contributor
Were you at version 2.1 or earlier when you first encountered this issue?
SeanSummers_CC
Yes, 2.0 if I remember correctly.
MonicaLloyd
We are also experiencing the same issue. Contour labels disappear when Maplex contour placement setting is applied. Running latest version or ArcGIS Pro 2.1.2. Several of my students are experiencing the same problem. Labels work fine if we use regular placement properties.
WendyHarrison
Hi Monica,
I'm not seeing any issues with contour labeling here.  Could you please send a package with just your contours and how you're trying to label them?
thanks
Wendy
MonicaLloyd
What is the best way to get you the data? It is taking a long time to create a project package.
Contour placement works ok when I do not have a .style file applied. Could there be a link to the symbology causing the problem?
Monica
WendyHarrison
what is the style applied to?  the label symbology? the label placement? or the feature symbology?
thanks
Wendy
NicholasBarger
I just ran into the same issue today.  Several weeks ago I created a tiled service from our contours that successfully used the contour label placement in MapPlex Labeling.  Today, in a separate project I tried to turn on Contour labeling and the labels disappear.  I'm currently using ArcGIS Pro 2.2.4 and I believe I was using the same version when I create my tiled service.
NicholasBarger
Ok... so here is an update for those still having problems with this.  This has something to do with data.  I had 2 layers, municipal boundaries and contours.  They both used "special" label styles, boundary placement and contour placement.  When the boundaries were on the contours turned off.. when I turned the boundaries off the contours would appear.  Initially I thought this was a bug...it still might be.  However, the fix was to replace the boundaries layer since it was the only thing causing the contours to turn off.  I symbolized it the same way and labeled it the same way and it corrected the contour labeling issue.
