How we get Feature count of 2 GDB(Include dataset and feature class) in CSV format.
4180
8
04-21-2022 04:23 AM
Rakesh_Kumar_GIS
How we get Feature count of 2 GDB(Include dataset and feature class) in CSV format in Model builder or script tool.
In CSV format GDB can differentiate with sheets and every sheet have count of respective feature classes.
2 Solutions
curtvprice
This can't be done in ModelBuilder tools, but you can use the Calculate Value tool like this in ModelBuilder.
Expression: proc(r"C:\users\me\my.gdb", r"C:\users\me\my.csv")
Code Block:
def get_gdb_feature_count(gdb_path):
    # set workspace to gdb
    prev_ws = arcpy.env.workspace
    arcpy.env.workspace = gdb_path
    # list all feature classes and tables in workspace
    fcs_and_tbls = arcpy.ListFeatureClasses() + arcpy.ListTables()
    # GetCount() on all of these
    counts = [int(arcpy.management.GetCount(ft)[0]) for ft in fcs_and_tbls]
    # revert workspace
    arcpy.env.workspace = prev_ws
    # return [ ["TableName", count] ]
    return zip(fcs_and_tbls, counts)
def proc(gdb, csv_path):
    result = get_gdb_feature_count(gdb)
    with open(csv_path, "w") as f:
        f.write("Name,Count\n")
        for r in result:
            f.write(f"{r[0]},{r[1]}\n")
curtvprice
Use ModelBuilder variables for example r"%gdb% and r"%csv%" - the path is substituted in at runtime.
JohannesLindner
Basic structure:
    # revert workspace
csv_path = "path:/to/your/csv_file.csv"
result = get_gdb_feature_count("path:/to/your/gdb")
    for r in result:
Have a great day!
Johannes
Rakesh_Kumar_GIS
Hi Johannes ,
Thanks your effort.
Please give me this script as a model builder.
thanks for advance,
Rakesh
JohannesLindner
Sorry, I don't know how to do this in ModelBuilder.
Try running the script in the Python Window first, that makes it easier to troubleshoot.
Have a great day!
Johannes
curtvprice
Code Block:
    # revert workspace
        for r in result:
Rakesh_Kumar_GIS
Hi curtvprice ,
Thanks for the reply.
can be set gdb path and csv  path as a parameter. if possible then please let me know.
thanks,
Rakesh
curtvprice
Rakesh_Kumar_GIS
Thank you so much !!!!!!!  curtvprice
But I observe its working on both are same folder path.
But any how... Its really usefull for me
thanks for your time in future I will defiantly reach you  🙂
Rakesh_Kumar_GIS
And I think its not write dataset name and inside the dataset feature class.
