How to turn off Transformation Warnings?
580
05-18-2022 04:15 AM
fred7
New Contributor III
Hello,
I am using ArcGis project that was started using an older ArcGis version (not Pro). Everything works fine except every time I open the project about 40-50 Transformation Warnings start to pop up after every 1-2 second and I must wait like minute or more before I can do something. It is very annoying. Is it possible to turn off the warning?
RobertBorchert
Frequent Contributor III
There are lot more details you may need to share but without them I will construe this.
Is your data in Shapefiles or a database?
It would seem that your date is in multiple projections that are not compatible with each other. Meaning they are made for a specific area and cannot mesh up with the data it shares a location with.
Possible solution would be to create a new database were all feature datasets use the same projection.  I would suggest using
WGS_1984_Web_Mercator_Auxiliary_Sphere
WKID: 3857 Authority: EPSG
Import all your data into the new Feature Data Set(s)
RobertBorchert
fred7
New Contributor III
I have over 50 maps with different water parameters in different days. I think it is easier to wait 1 minute rather than to import all those maps to new Feature Data Set. I was thinking that there is an option to turn off the Transformation Warnings (or any other pop-ups) but it seems that there is not.
But thank you for the suggestions!
Robert_LeClair
Esri Notable Contributor
Yes, there is a way to turn off this functionality.  Go the Project tab->Options and in the Application group->Map and Scene.  Expand Spatial Reference and uncheck "Warn if transformation between geographic coordinate system is required to align data sources correctly."  Voila - no more warning messages.
fred7
New Contributor III
Thank you, but that checkbox is empty by default.
