How to speed up ArcGIS Pro?
4543
9
12-22-2020 04:01 AM
treistadbakk
I have read a lot about users struggling with ArcGIS Pro being very, very slow. For two years I have been hoping this is just temporarily. Even on small datasets stored locally, a simple command like "merge" (polygons), "clear" (selection) or "save "edits" may take 2 or 3 minutes. And the program freezes between these commands. ArcGIS Pro is really a drag and something I really avoid when I can. I usually have a an ArcMap mxd-document "on the side" to perform certain tasks because ArcGIS Pro treats even the simplest task as something heavy and complicated. Merging two polygons takes half a second in ArcMap, but ages and ages i ArcGIS Pro. The developers have really done a lousy job here, and the software should have been tested  and improved before rolled out.
MichaelVolz
Esteemed Contributor
What version of Pro are you working with as ESRI has now rolled out Pro 2.7?
treistadbakk
2.6.3 at the time. Updating now 🙂
DanPatterson
MVP Esteemed Contributor
What are your computer specs as reported from the link on this page that tests your computer's ability to run it
ArcGIS Pro 2.7 system requirements—ArcGIS Pro | Documentation
I have been on every beta for Pro and never experience any of these slowness issues, particularly when doing geoprocessing.  But I only work with locally stored data in file geodatabases.  I routinely delete and clean out my gdbs and scratch gdbs.  Deleting my geoprocessing history is done daily. I don't keep a bunch of useless maps around, I dont use basemaps .  Lots of flotsom can slow down a project, so you will have to describe your situation.
... sort of retired...
treistadbakk
Thank you so much for your reply and useful inputs.
My Dell PC is an i7-8850H CPU @2.59 GHz, 32 GB RAM, Win10(64-bit). Should be OK?
I've never deleted geoprocessing history or performed any gdb clean. If that really slows down ArcGIS Pro, ESRI should be informed so they can removed that bug. But I'll try to follow that advice!
Working without basemaps doesn't sound to be a good solution, not to me. The maps have to be presented, and working with planning I really need to know where I am on the map to know what I am doing. Maybe you have two project files? One for geoprocessing and one with maps for presentation?
Of course I don't "keep a bunch of useless maps around" 🙂 The maps and datasets I import, generate and use are there for a reason. I really think that ArcGIS Pro should be able to perform geoprocessing/editing even if there are other datasets loaded into the project. Like good old ArcMap can.
DanPatterson
specs should be Ok. but you need to run the link in the link I posted to get a comparison on how your machine stacks up.
TamsenWaldron
I still have these issues and I'm running the newest version of pro and have a very fast machine.  I still like ArcMap way better.
MatthewSackrison
Running 3.3.1 and the situation has not improved. I'm using a high-end machine that exceeds the recommended hardware requirements in every area, but just something as simple as selecting a feature still takes several seconds and then everything redraws so you can't even see if you selected what you wanted to until several more seconds. Why are these simple tasks still so terribly slow nearly 10 years after the initial ArcGIS Pro release? Makes the program essentially unusable for any sort of editing or production work.
Bud
What version of ArcGIS Pro? What kind of geodatabase?
I found disabling indexing helped.
treistadbakk
Hi and thank you for replying.
I don't know what you mean by "kind of geodatabase". Are there different kinds? I'll try disabling indexing.
