How to run Arcade calculations only on blank cells
594
02-06-2020 12:47 AM
ElizabethNaro
Hi all,
I have a feature layer updating monthly from a Survey123 form and there are a few Arcade calculations that I need to run on the new data. Some of the calculations use a lot of computing power and could take over 30 minutes to run on the entire data set...and I assume it'll only take longer each time new data are submitted.
Is there a way to only run the calculations on the newly submitted data instead of rerunning them on the entire dataset every month? I've tried IsEmpty but am having trouble getting it to leave (false) cells alone. Thoughts?
