How to return unique values from the field/column of table fgdB?
411
13
a week ago
BSBlagojevic
How to return unique values from the field/column of table fgdB which participates in the relationship 1:M? I need unique values for the related report. Distinct keyword in Arcade does not do this on field/column (only on array, tested), and in SQL for file geodatabase this keyword is not supported!
Thanks for any help!
KenBuja
This goes back to my previous post
How you get the features variable depends on where you're using the Arcade code. It could be using the variable $datastore or $layer. Or you might need to get it from a function like FeatureSetByName or FeatureSetByPortalItem
What happens when you use "$datastore"?
BSBlagojevic
Thanx! NOT PASS!
Regards!
KenBuja
That code should be
var features = FeatureSetByName($map, 'Kartirane geoloske jedinice', ['PreferisanaStarost'], true);
Distinct(features, 'PreferisanaStarost');
BSBlagojevic
Thank you! Again problem!
