How to resolve ArcGIS Pro OrthoMapping Orthomosaic errors?
2329
10-17-2017 01:45 AM
LaszloCsunderlik2
I have simple drone images (around 1000) from an agriculture area. After the Adjust I ran an Orthomosaic but the result not meet with my requirements. I had an orthomosaic with a lot of wrong mosaics, see attached. First I thought the wrong mosacing occours because of the seamline settings. I set up a lot of different parameters in the Seamline Settings, I trired with a lot of different Computation Method but the errors were still the same. Someone has any experience about the problem?
(On the attached images the blue lines are seamlines.)
László
Mark_Wilson
Hi Lazlo - were you at Portsmouth Uni MSc? I am trying to do a similar thing.
Mark Wilson
LaszloCsunderlik1
Hello Mark
No. Did you get any acceptable result?
