How to remove <all other values> from Legend in ArcPro
51856
14
08-29-2017 05:05 PM
BenVan_Kesteren1
Hey Guys,
I am having a go at using ArcPRO to create a simple map, I am doing OK right up until I have to create the legend.
Is there a way to filter off and not display the <all other values> from my legend?
I click on the symbology, and right click on this item and I am unable to remove this symbol (this is expected, as I know in arcMap this is the same)
Disabled Option
So, I am sure in ArcPro I should be able to remove this option from the legend, can someone explain to a n00b how to do this please?
unwanted <all other values>
2 Solutions
DanPatterson_Retired
In arcmap, I just used to do another hack... but only useful for layouts... which was to convert the legend to graphics... ungroup... delete what I didn't want... regroup and it was done.  Wait!!
Found it
BenVan_Kesteren1
Fantastic, thanks for that... I kept clicking 'more value' thinking thats where you were indicating, and then I expanded my field of view and found the 'more' button you said to click!
Thanks heaps, works exactly as expected.
SOLUTION
hmmmm I wonder if you could just use a space for the label, set the fill to blank with no outline.... or this
BenVan_Kesteren1
Hey, thanks for the suggestion.
I did try what you suggested by changing colors to NONE and no label, but it is just a n00b hack and not a proper solution, as it keeps the blank line in the legend which is not very professional I believe. I know I can re-order the layers, which will work in this instance to put the blank line at the bottom, but what happens if all my layers have <all other values>?
I was hoping for a tick box or something that is hidden somewhere...
blank space
Found it
BenVan_Kesteren1
SOLUTION
Douglas_Sauer
not exactly intuitive locate to remove all other/null values...
curtvprice
Even better, in 2.4.1 this has been moved to the top of the menu instead of way down at the bottom!
AmyNewsam
Is there any way to remove it JUST from the legend?  Other than converting to graphics?
TomBole
Hi anewsam Newsam,
Currently, there is no way to remove this from JUST the legend without converting the legend to graphics.  This souinds like a good enhancement.  There are a couple of ideas on https://community.esri.com/community/arcgis-ideas that are similar - Cleaner "All Other Values" in legends. and Legends in Pro All Other Values. You may want to add your comments and vote.
Tom
AmyNewsam
Thanks, Tom.
Amy Newsam
GIS Specialist
SpARC Lab
SSM 209​
Open Lab Hours: 10am - 4pm (M-Th)
