How to performe Climate analysis in ArcGis Pro?
2701
09-25-2018 08:49 AM
ChristopherPolo_Dominguez
Hi, I'm new using arcgis pro I will like some help to perform a climate analysis (temperature, wind, rain, solar radiation, etc.) of an area of my city Santo Domingo, Dominican Republic.
Is there any tutorial or step by step to do this? Where I can find some data?
Please Help!
DanPatterson_Retired
Here are some of the tutorials accessible through the help topics
ArcGIS Pro quick-start tutorials—ArcGIS Pro | ArcGIS Desktop
Then there is the whole esri training materials
https://www.esri.com/training/
I think that concentrating on the gis skills than the data might be the route to go.  You will need the skill set regardless of the data you are applying it to
TimOrmsby
In addition to Dan's suggestions, check out Learn ArcGIS  which has tutorials oriented to specific problems. There's one called Explore Future Climate Projections that will probably interest you. And see Kory Kramer's post ArcGIS Pro Learning Resources. For your work, you might want to concentrate on learning about raster data processing and analysis.
Another good resource in Learn ArcGIS is Get Started with ArcGIS Pro, which focuses on analyzing flood risk in Venice, Italy, so also has a climate-science orientation. The quick-start tutorials mentioned by Dan are a very good introduction to ArcGIS Pro; unfortunately, they're not strong on raster data analysis.
JoanneParkinson
To tag on... there's also a web course available on the Esri Training site - Working with NetCDF Data in ArcGIS Pro.
