How to make a Delaunay triangulation with points (only X,Y coordinates; without elevation)
1911
06-16-2022 05:15 AM
ConnieSu
I need to link points that have only X,Y coordinates (without elevation) with a Delaunay triangulation. However, when I use "Create TIN", it shows a error message and don't create what I need. Any suggestions?
Thanks and regards!
Tags (1)
DanPatterson
MVP Esteemed Contributor
ConnieSu
Thanks for your reply and your help! I've downloaded the files and tried to use the toolbox; however, as I'm using ArcGIS Pro 2.9, it won't work, right? I've got some error messages:
" Traceback (most recent call last):
  File "C:\PythonStart\tbx_tools.py", line 810, in <module>
    elif tool in ['Bounding Circles', 'Convex Hulls', 'Extent Polys',
  File "C:\PythonStart\tbx_tools.py", line 801, in _tool_
    all_flds = cls_flds + [stat_fld]
  File "C:\PythonStart\tbx_tools.py", line 755, in pick_tool
    # tbx = ImportToolbox(tbx)
  File "C:\PythonStart\tbx_tools.py", line 577, in tri_poly
    out_kind = shp_kind
  File "C:\PythonStart\tbx_tools.py", line 219, in _in_
    r"""Check file name and file path for compliance.
  File "C:\PythonStart\npg\npg_arc_npg.py", line 285, in fc_to_Geo
    cols = IFT_.shape[0]
UnboundLocalError: local variable 'IFT_' referenced before assignment
Failed script Delaunay...
Failed to execute (Triangulate)."
