How to install Anaconda using ArcGIS Pro 2.1?
2603
6
01-22-2018 05:53 PM
RyanTucker2
How to install Anaconda using ArcGIS Pro 2.1? Is this possible? I see it listed in the python package manager. Yet every time I try to install it ,it doesn't seem to work. It starts to install then 2 minutes later it refreshes and hasn't installed.I have full admin rights. Not quite understanding why it fails to install.
DanPatterson_Retired
I wouldn't go installing anything just yet.  Your whole installation of Pro is in an Anaconda package .
For example... I have Pro installed in this path
C:\ArcGISPro\bin\Python\envs\arcgispro-py3
yours in installed in the path before the \bin.... folder.
The \envs... folder probably only contains one folder (ie ArcGISpro-py3)
You can use conda to install variations of the distribution if you want to, but I recommend not messing with your Arc* machine.
The packages can be installed within the package manager within Pro or you can do it via conda.
I have a couple of blogs on installing other packages (ie Spyder, Jupyter Console, Jupyter Notebook etc) if you are looking to do other package installs.
Good luck
Good luck
Python Package Manager ... from the help, for further info
AmyKlug
I'm trying to get a general idea of how to use conda in Pro to be able to run a 2.7 environment. Do I create a new environment in Pro and set it up with the 2.7 library package?
you could, but I wouldn't.  Python 3 can be used as a substitute for 2.7 for most python things and all arcpy thing.
AmyKlug
Thanks Dan, We need to use older scripts.
Sounds like you are saying that workflow is possible. Unfortunately creating a new environment in pro and trying to load it isn't working for me. creating a new environment "failed"
RyanTucker2
Thank you, Dan.
I ended up installing the Spyder IDE package and it works fine.
