How to get the closed map back in pro?
9036
01-09-2020 07:07 AM
KeWang1
New Contributor II
I downloaded other people's package to learn, I accidently closed all the map in the package then saved the changed, then closed the arcgis pro. Next time when I opened the package again, there is totally blank in pro. Even I redownlaod the package from the same place and open it, there is still nothing. How to get the closed map back?
XanderBakker
Esri Esteemed Contributor
Hi tony.kewang ,
There are a couple of ways to open it again, using the contents pane, catalog pane or catalog view:
XanderBakker
Hi tony.kewang ,
KeWang1
New Contributor II
Thanks a lot!!!!!!!!!!!
XanderBakker
You are welcome tony.kewang . Could you mark the post that answered your question as the correct answer? This way other users will be able to find the answer easier.
MatthewDriscoll
Note you can only use the Contents pane if the Catalog view is active.  I was scratching my head as I did not know that this would show up in the Contents pane, thanks Xander I learned something new today.
