how to get layout coordinates from a feature in a map?
780
07-05-2024 08:45 AM
AlexanderGray
Honored Contributor
I am using ArcGIS pro 3.3.1, arcpy
I have a layout with a map frame.  Map frame has a map, map has a point feature class layer, feature class has point feature, point features have X,Y coordinates in the featureclass's coordinate system.  I need to get those coordinates in layout coordinates.  Think automatically adding a graphic of an arrow that starts outside the map frame with the end of the arrow pointing to the point on the map (not exactly what I am doing but gets the point across).  If I can get the coordinates in layout space, then I can create a graphic on that spot of the layout that covers the point in the map.
Tags (3)
