How to fixed the size of the map?
579
12-14-2021 02:59 AM
altair
Hi all I hope you all doing well, I have a problem regarding of sizes of map, in the first load the size is good and correct and when the data is load the size of the map is changes, please check the image below
first load
after the data finish the load
const [getUserData] = useLazyQuery(ME);
const [getLocations] = useLazyQuery(GET_ALL_Star.);
const mapDiv = useRef(style);
let orgId = null;
useEffect(() => {
location();
const fetchData = () => {
getUserData()
.then((result) => {
return result.data;
.then(({ me }) => {
orgId = organization.id;
return getLocations({
variables: {
paging: {},
.then((result) => {
return result.data;
.then(({ location}) => {
displayLocation(location)
const location = () => {
if (mapDiv.current) {
esriConfig.apiKey = process.env.ARCGIS_API_KEY;
const map = new Map({
basemap: 'arcgis-light-gray',
const view = new MapView({
center: [123.5504, 12.3574], // Longitude, latitude
container: mapDiv.current,
map: map,
zoom: 2, // Zoom level
autoResize:true
view
.when((r) => {})
.then(() => {
mapDiv.current = view;
fetchData();
const displayLocation = (locations) => {
locations.data = locations.data.filter((l) =>{
return l.geoCode && l.orgId == orgId;
const centerLocation = CalculateCenter(locations);
const zoom = CalculateZoomLevel(mapDiv, locations);
mapDiv.current.center = [centerLocation.longitude, centerLocation.latitude];
mapDiv.current.zoom = [zoom];
mapDiv.current.autoResize= false;
locations.data.map((location) => {
const point = new Graphic({
geometry: {
latitude: location.geoCode.latitude,
longitude: location.geoCode.longitude,
type: 'point',
symbol: StarPin,
mapDiv.current.graphics.add(point);
return <div className="mapDiv" ref={mapDiv}></div>;
Bo_King
Esri Alum
Hi Altair
Below are some links to recourses that might answer your map extent questions.
Add data to a project - ArcGIS Pro | Documentation
Set the map extent - ArcGIS Pro | Documentation
I am moving this question to the ArcGIS Pro Questions board, so that the broader community might provide additional insight.
Regards,
Bo
