How to delete "New_Projected_Coordinate_System"?
1350
10-31-2021 09:46 AM
ULYSSESPASCAL
I accidentally created a custom projected coordinate system called "New_Projected_Coordinate_System". How do I delete this?
I created a copy of this custom projection and renamed it to the correct name but I cannot delete the original custom projection. Now when I export georeferenced images using the correctly named PCS in the drop down menu, arcgis pro automatically labels the georeferenced image with "New_Projected_Coordinate_System" in the metadata. Even when I try to reproject the raster specifically using the correctly named PCS, the metadata says "New_Projected_Coordinate_System". This is just a naming difference (both PCSs have the same settings) but it is frustrating.
DanPatterson
try removing it from "favorites"
... sort of retired...
