Good morning,
How to Create Relationship class based on GLOBALID/GUID from a feature class to a table.
Thanks.
I was able to create a relationship between a feature class and a table by using the GlobalId from the feature class and a new field called SiteGUID in the table, which is of type GUID.
Thanks
What version of Pro are you using? Manually created relationships that use GUID types used to be flaky but I'm on Pro 3.1 and I've created dozens of them with zero issues. Simply ensure the origin/parent item has GlobalIDs enabled and the destination/child item has a GUID type field. Then create the relationship class and pick the appropriate fields. Note that GlobalID to GlobalID won't work as the relationship can't override any existing values here.
A long integer type is required for the common fields
Geodatabase relationship class fundamentals—ArcGIS Pro | Documentation
or are you looking to migrate one?
Migrate Relationship Class (Data Management)—ArcGIS Pro | Documentation
Signed in members can post, follow updates, and more. New here? Register a free account.
