How to create points at each vertex of a polyline with interpolation of elevation from points
1086
05-04-2020 02:52 AM
NehruKhandrika
Hi I have a polyline feature class digitised as the water edge lines. I have some points which have elevation data. I would like to proportionate the elevation between the points againist the vertex of the polyline between the points. Any Ideas or an existing solution would be great.
DavidPike
MVP Notable Contributor
Something like Interpolate Points—Standard Feature Analysis tools | Documentation  would generate a raster surface, then feature vertices to points, or points along line to then extract the raster values coincident with the points?
