How to Create Isopachs, Isochrons and Seam Floor Contours in ArcGIS Pro
3319
08-08-2023 10:45 PM
jantolihao
Hello, everyone!
Does anybody know how to create isopachs, isochrons and seam floor contours in ArcGIS Pro? Is there a tool in the geoprocessing toolbox that can help me generate those types of contours? I know how to generate a "normal" contour from elevation surface but having a hard time finding a solution to generate the mentioned types of contours above.
Appreciate any help or hint regarding this matter. Thank you very much.
MiguelParedes
Greetings @jantolihao
If you have generated contours in the past using ArcGIS Pro, you may be familiar with the following articles, but if not, please have a look at Create contour line in ArcGIS Pro and Contour function. When it comes to isochrones (Service Areas), you will need the Network Analyst extension as explained in Visualize the reachable area with Service Area tutorial. Also, have a look at the Service area analysis layer.  Alternatively, you could use the TravelTime ArcGIS Pro Add-In available from TravelTime which is available through the ArcGIS Marketplace
Hope the above can be used as a guide.
Miguel
MiguelParedes
Miguel
jantolihao
Hello, @MiguelParedes.
Thank you for the response. This is really helpful.
