How to create a dash line symbology with ticks in the middle of the dash?
1530
08-29-2022 06:37 AM
TomGeo
I am trying to create a symbology like the one in this screenshot
I created a dash symbology for the line as solid stroke with an dash template of 9 10, and copied this layer.
To the new solid stroke layer I added the rotation effect (90º), and altered the dash template to 4 10.
Then I adjusted the 'At line ends' option to: Half pattern.
The result:
How can I get the tick placed in the center of each dash?
I was playing with the 'At line ends' option and the 'Dash template' option, to no avail.
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
JohannesLindner
You could use marker layers.
  • create a marker layer, delete the stroke layers
  • Choose this form
  • rotation: 90°, Placement = Along line, check Angle to line
  • play with the other parameters
    • eg: Line width = 1pt, Size = 15pt, Placement template = 30
  • Copy the layer. in the copy:
  • rotation = 0°, change line width, size, and Perpendicular offset to match
    • eg: Line width = 3pt, Size = 7pt, Perpendicular offset = 3pt
Have a great day!
Johannes
JohannesLindner
  • Choose this form
Have a great day!
Johannes
