How to convert file geodatabase(.gdb) to runtime geodatabase(.geodatabase)
2667
09-02-2021 07:20 AM
2xlearner
I have File geodatabase(.gdb) and I am trying to convert it to runtime geodatabase(.geodatabase). I found conversion methods in internet from runtime geodatabase(.geodatabase) to file geodatabase(.gdb). But could not find the reverse. I want to use .geodatabase in ArcGIS runtime
Nicholas-Furness
You will need ArcGIS Pro 2.7 or later. That should allow you to create a mobile geodatabase (.geodatabase file) that can be opened in ArcGIS Runtime 100.12 onwards (earlier versions do not support .geodatabase files created in ArcGIS Pro). You can use ArcGIS Pro to populate the mobile geodatabase from your file geodatabase.
Read more about the geodatabase types here.
Hope that helps.
2xlearner
@Nicholas-Furness  I create  mobile geodatabase(.geodatabase) and I have DTED in File geodatabase folder. How can I add that data to mobile geodatabase. I created table in mobile geodatabase then right clicked on table and select "load data" option. I choose DTED as input but I don't know what to choose as target dataset.
By the way, I use ArcGIS Pro 2.7
Nicholas-Furness
@2xlearner I think you'll get a better answer over in the ArcGIS Pro Questions community. I've moved the post over.
David_Brooks
MVP Regular Contributor
@2xlearner , Mobile Geodatabases don't support raster data, so you might need to look at creating a mobile map package or mobile scene package.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/create-mobile-map-package.ht...
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/create-mobile-scene-package....
David
..Maps with no limits..
