How to calculate and display area coverage in percentage
4197
02-12-2022 06:47 AM
caustics
I'm working on a task where I had to create 3 classes for different land use forms that cover a city area. I have to display the coverage of each area of the city in percentage on my map. I have 4 layers, one is the city outline and the other 3 are the 3 land use classes. How do I display the area information in form of a legend (like a table or something like that) on my map?
DanPatterson
MVP Esteemed Contributor
caustics
Thank You for your quick answer!
Now I have 3 Tables as layers with the results. Is it possible to merge them all in one single table? and how do I display the results on the map ?
DanPatterson
You should merge the landuse classes first to get one file, then tabulate area so you end up with all the data in one table as in the image in the link
Tabulate Intersection (Analysis)—ArcGIS Pro | Documentation
The rest is homework, and involves symbolizing and other map stuff 😉
... sort of retired...
caustics
Thank you!
sabahfree
I think that you should use coding and classification as well as
display the uses in the form of pargraph charts, where the systems
software provides these features appropriately and with multiple
capabilities
