How to add new field in an attribute table?
11978
17
05-23-2018 07:13 AM
deleted-user-vI4FgtGn3D1S
Dear, does any one know how to add a new filed in an attribute table? First I open the attribute table of a shape file, and click the upper left button of "add field". After it pops up a new tab of attribute table, I get totally lost, couldn't  figure out what to do next. The add field button on the top is grey, and the operation is so much different from GIS 9.3.
Tags (1)
KoryKramer
Esri Community Moderator
Are you using a shapefile? And do you have a Basic license of ArcGIS Pro?
If so, the following bug is logged [BUG-000101840: Unable to add fields via the New Field feature for shapefiles in ArcGIS Pro using an ArcGIS Pro Basic license.]
You could also try working with a file geodatabase.
GregRumpel1
Kory...Is it possible to talk to you on the phone regarding my question that you responded to regarding drawing...from segment to curve back to segment
Greg
MichaelVolz
Esteemed Contributor
Was this bug fixed in Pro 2.1.3?  I ask because I changed my Named User Pro license from Standard to Basic and I then created a shapefile where I was able to add a new field and save this change to the shapefile.
KoryKramer
Michael, no this isn't marked as fixed. I tested with a shapefile and basic license in a Pro 2.2 build yesterday and reproduced the behavior.
MichaelVolz
What kind of licensing are you using Kory - Named User, Concurrent Use, Single Use?
KoryKramer
Named User - Basic - Just tried in Pro 2.1.3 and the problem persists.
PaulaGiryn
I also have this problem still. I am using a concurrent license- Basic-I just tried in Pro 2.4.1 and the problem still persists even now.
KoryKramer
Are you certain that you've installed Patch 1?
If what you're seeing is related the the bug referenced above, it was addressed in Patch 1: https://pro.arcgis.com/en/pro-app/get-started/release-notes.htm
I just tried:
and was able to add a new field to a shapefile using both the Fields View (UI) as well as the Add Field gp tool:
