I have an aprx with two maps. They do not contain the same data. I am trying to write a script that allows me to perform a search cursor on data in one map and then use the results to perform analysis (select layer by attribute) and zoom on the second map. I have not been able to find a method to "switch" the active map in the documentation. Has anyone had luck working with multiple maps in using arcpy?
