How enlarge image attachment in pop-up windows?
1135
10-26-2017 01:36 AM
SMauri
How is the quicker way to enlarge an image associated to a point as attachment? I'm using ArcGIS Pro 2.0.1.
From pop-up is not possible to click on thumbnail like in HTML pop-up of ArcMap. And you can't set a resolution for image in pop-up
To reach file image I found two method:
1) open Attribute table and right-click on selected elements and select "Manage Attachments" from pop-up menu.
2) double click on name file in Attributes tab
Any other idea?
Stefano
White_David
I was having the same problem, however it is ( now anyway ( v2.3.2 )) simply a case to on the configure pop ups screen tick the box which says Show list of Attachments.
Then when you ID a point the photo.jpg will have a link to click and it will open in your default picture viewing software.
