How do you get the elevation on click in an ArcGIS Pro 3D Map
694
11-14-2019 08:18 AM
DanielWebb
I'm using a DEM for the Elevation Surface but I can't figure out how to identify the elevation by mouse click at a certain location.
If the raw DEM is also in the 3D map I can do it. But that means having two DEMs drawing in the map at any given time.
Is there a way that I can click the 3D Elevation Surface to get an elevation?
Thanks!
CM0001
For late arrivers to this question. In Pro, go to View -> Convert to Global (or Local) Scene to get map into a 3D map version. Then when you click around on the map the elevation is shown at the bottom center message line below the map.
