How do I replace the first character of a string using calculate field in ArcGIS Pro?
6607
6
07-28-2020 09:25 AM
JoeLivoti
Pretty simple question I'm sure for the Python people out there. I have a field, FACILITY ID, that is populated as string values as 00001,00002, 00003, and so on. All values in the field are 5 characters long. I want to change the first number in to a 1 so the values of the field look like 10001, 10002, 10003, etc. I'm pretty sure i should use the .replace(), but I cannot format it correctly. Any advice would be very welcome. Thank you.
DanPatterson
MVP Esteemed Contributor
"1" + !YourField![1:]
python parser and YourField is the field that contains the original.
It is best to do calculations in a new field in case things go real bad.
You can copy them back into the original later
... sort of retired...
DanPatterson
JoeLivoti
Dan,
Thank you that worked perfect. How would I augment that to change a different value in the string, say the second value to a 5? Again thank you!!!!
JoshuaBixby
Although you asked a follow-up question, Dan addressed your first question.  Please mark his response as Correct to close out the question.
DanPatterson
"15" + !YourField![2:]
or if you just mean the 2nd value, leaving the first along
!YourField![:1] + "5" +!YourField![2:]
JoeLivoti
Thank you Dan!! The second one was exactly what i needed!
DanPatterson
no problem
