How do i export atribute table data from ArcGISPro to excel?
2983
6
03-05-2019 01:22 PM
vincezubia
DanPatterson_Retired
If there is a selection in the table, the selection should be honored on export.  Did this not happen?
Table To Excel—Conversion toolbox | ArcGIS Desktop  but read the fine print on using/working with excel
vincezubia
Victoria,
It seems like it wants export all parcels, but I just want the selected ones.
Vince Zubia
GIS/Plat & Subdivision Specialist II
El Paso Central Appraisal District
5801 Trowbridge Rd.
El Paso TX. 79925
(915) 780-2012
FAX: (915) 780-2010
vinzubia@epcad.org<mailto:vinzubia@epcad.org>
[cid:image002.jpg@01D4D362.A1CEFE20]
vincezubia
I exported the data with a tab on top table, then export. Output name project.csv and it worked.
Thanks, Vince
VictoriaAnderson
Vince,
You can export attribute table information to a table by right clicking on the feature layer, going to "Data" and
choosing "Export Table".
This will open the "Copy Rows" geoprocessing tool. Here, you can specify your output table.
After you export these attributes to a table, you can use the "Table to Excel" tool to convert this to a .xls or .xlsx file.
vincezubia
Got it thanks.
