I have created a new field in the attribute table Called "new_labes".
I then right-click on 'new_labels' to open the calculate field tool I then concatenate other fields such as SAF or SRM in the attribute table. the result is giving me the Coded name and not the description as it was previously was viewed in the attribution table for SAF or SRM.
EX:
Before : SAF=pine tree and After: In new_labels SAF value is seen as 001
I did notice that SAF does have a domain type as coded value domain which 000 = pine tree
how do I concatenate fields and get results of what I see in the attribute table and not the coded values in the new field created new_labels?
