How do i capture and use user input in an ArcGIS Pro Task?
2737
09-12-2016 04:02 PM
BradBurford
I want to use a task to perform a Selection by Attribute, prompting the user for a value to be used in an expression. I believe the Get Attributes command is the way to prompt for user input. However, I can't find documentation on how to reference the variable created in the Get Attributes step for use in the Select by Attribute Geoprocessing tool. Is this even possible?
DanPatterson_Retired
Is it the basic task link you are missing? What is a task?—ArcGIS Pro | ArcGIS for Desktop
