How can a calculation field be added to a read-only portal layer
324
11-14-2024 06:31 AM
MarcusAdamski
I've added a feature layer from my company's portal to a map within my Pro project. I would like to run the Calculate Geometry Attributes utility on the layer to calulate areas. However, the attribute table is read-only, so a new calc field cannot be added. If I right click on the layer, both Data->Export Features / Table are disabled.
What's the best approach to perform a Geometry calculation on a read only layer?
Many thanks,
Marc
Laura
by MVP Regular Contributor
Have you tried the feature class to feature class or copy features tools?
