Help with Intersect / Intersection Attribute Rule
3335
6
09-30-2021 09:25 AM
Robswann
Hello, I am trying to determine the correct rule code for determining the amount of acreage within another polygon.
For Example: I have a feature named Tracts that may or may not contain floodplain acreage (Feature name Floodplain).
Could someone help me out? ..... This is what I have now.... but it is not pulling the correct acreage, and I think the correct function would be INTERSECTION, but not sure.
Thanks again
VAR FLOODPLAIN = FeatureSetByName($datastore, "RES_FLOOD_HAZARD")
VAR INTERSECTSFLOOD = INTERSECTS($FEATURE,FLOODPLAIN)
area(intersectsflood, 'acres')
Tags (1)
2 Solutions
jcarlson
You guess correctly, you'll need Intersection to get the geometry of the overlapping area. However, this function requires two geometries as parameters, and you're working with a FeatureSet.
Simple Version: Getting Intersection of Single Feature
var floodplain = FeatureSetByName($datastore, "RES_FLOOD_HAZARD")
// Grab the first item for the intersects featureset
var flood_feat = First(Intersects($FEATURE, floodplain))
// Get intersection, calculate area
var xs = Intersection(flood_feat, $feature)
// Calculate acreage
return Area(xs) // multiply by some value, depending on the area units in use
However, a single tract may intersect with multiple flood zones, and we may want to capture this information.
Complex: Return a List of Intersected Areas
// Get FeatureSet of intersecting flood zones
var flood_fs = Intersects($FEATURE, floodplain))
// Instantiate output string
var out_str = 'Flood Zone Acreage:'
// Iterate over FeatureSet
for(var f in flood_fs){
    var xs = Intersection(f, $feature)
    var a = Area(xs) // multiply by some value, depending on the area units in use
    // Append to output string
    out_str += `\n${f.flood_zone_identifier_field} | ${a} ac`
return out_str
This will return something like
Flood Zone Acreage:
Zone AE | 12.1 ac
Zone X | 6.23 ac
- Josh Carlson
Kendall County GIS
jcarlson
Oh, sure! Instead of an output string, you could just use a numeric value. Make these changes to the "complex" expression and see how it works.
Line  7 → var out_area = 0
Line 18 → out_area += a
Line 21 → return out_area
So instead of creating a cumulative string, you're adding up cumulative sum.
- Josh Carlson
Kendall County GIS
jcarlson
return out_str
Flood Zone Acreage:
Zone AE | 12.1 ac
Zone X | 6.23 ac
- Josh Carlson
Kendall County GIS
Robswann
Thanks again for the help. For some reason the expression states it is valid, but will not save? I have tried everything from saving closing out, restarting ?
Robswann
Thanks @jcarlson Any way I could just sum all the zones within that feature to return a value of the total flood acreage?
jcarlson
- Josh Carlson
Kendall County GIS
Robswann
This is very helpful. Thanks again!
Robswann
Thanks I figured it out, any way I could just sum all the zones within that feature?
