Hello All,
I am trying to publish a web layer from ArcGIS Pro to ArGIS Online. I've done this successfully before in AGP2.5, but haven't used the software for some months, so am trying to get back up the learning curve.
This ought to be straightforward - it is a georeferenced raster map which I want to publish as a Tile to overlay on a basemap in an AGOL project. Consistently I am getting a 'Publishing web layer failed' message - see screenshot attached. Frustration is now getting the better of me - steps I have tried:
But I'm still getting the same message - feels like there must be something really basic that I am missing, so grateful for any suggestions.
Many thanks,
Nigel
Hi Nigel,
It looks like you configured the web tile layer to cache locally. Can you try using the Create Map Tile Package GP tool to create the tile package? Next, use the Share Package geoprocessing tool (check Publish web layer) to share the web layer. Does it work this way?
After you try this, it may still be best to contact technical support so that they can take a closer look.
Best,
Jonah
I also encountered this issue a number of times in the past, where the service definition seemed to upload fully, but failed at the "Publish" step right at the end.
I could never quite figure out why it seemed to happen some of the time, but not consistently. It sounds like you've tried all the usual steps, too. Is it possible for a coworker or other user to attempt the same process with a different username?
Definitely worth trying Jonah's suggested workflow - it got me part way there, before triggering a bug report error.
Hi, have you foun the solution to 'Publishing web layer failed' error?
I'll appreciate your answer.
