heat Map Symbology
2144
03-12-2023 09:19 PM
NasratullahOmari
I can't find heat map symbology in the new version 3.1; how can I symbolize a layer with heap map?
ChristopherCounsell
MVP Frequent Contributor
Heat map symbology draws point features as a dynamic, representative surface of relative density.
You have selected a polygon layer. It's not possible to create a heat map from a polygon layer.
You can choose a different method - such as an attribute (population) to symbolize the boundaries?
ChristopherCounsell
https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/heat-map.htm#ESRI_SECTION1_AE...
Above documentation link has the steps.
If you can't see it:
  • Ensure you have the layer selected
  • Ensure it's a valid layer type i.e. a feature layer
  • Maybe check another layer to ensure it's not specific to the data?
NasratullahOmari
I have selected my layer, but in the symbology pane, primary symbology down arrow I can't find heat map.
ChristopherCounsell
