Get route m-value at point-clicked using Arcade?
4930
13
03-05-2020 07:42 AM
NickHarvey
Hi All - I see that it is possible to access x,y,z, & m values for a custom pop-up using Arcade. The code below appears to be working in ArcGIS Pro 2.5.0 per my route layer:
var line = Geometry($feature)
var paths = line.paths;
var startingpoint = paths[0][0];
return text(startingpoint)‍‍‍‍‍‍‍‍
However, I'm not yet understanding how to return the m-value for any point along the route that was clicked, rather than the centroid or endpoints.  The m-value I'm looking for appears in the pop-up panel at lower right in ArcGIS Pro 2.5.0 (see pic below).
Any assistance appreciated!
2 Solutions
XanderBakker
Esri Esteemed Contributor
Hi Nicholas Flett and nickharvey
The limitation with Arcade is that you start off with the geometry you clicked on (you M-enabled line) and not the point location of where you clicked. Therefore, it is not possible to determine at which location of the line feature you clicked when using Arcade. The SDK should allow you to do this, although the complexity of the implementation will increase.
AyanPalit
Updating this old thread for tracking and community documentation. Get route m-value at point-clicked is out of the box Pro function and doesn't require any custom code.
At ArcGIS Pro 2.4, the Navigation > Explore tool included this enhancement.  You can view m-values in a pop-up for a feature that contains measured values (m-values) in their geometries. The coordinate display at the bottom of the pop-up includes the m-value closest to the clicked location in the map or scene. For linear geometries, the value is calculated by interpolating between the nearest vertices.
Pop-ups for M-aware features
Related thread Link with Screenshots.
There is also LRS Identify widget in Experience Builder for web apps.
FYI @KatyLewis
Ayan Palit | Principal Consultant Esri
BenTurrell
Hey Nick Harvey‌,
Try this:
var startingpoint = paths[0][0]["x"];
Ben
If this answer has helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
NickHarvey
Thanks for chiming in Ben - You're right...I can get to the m-value for the starting point of the route by replacing "x" with "m" for example...But I'm chasing the m-value for any point along the route, as it appears at the bottom of the pop-up panel at 2.5.0 where the route is clicked.  My idea was to build a calculation(expression) in the pop-up which uses this m-value as a variable.  The m-value is being populated at the bottom of the pop-up panel.  I'm not understanding how to reference it into the pop-up body though (?).
by Anonymous User
Not applicable
Hi Nick,
Did you make any progress with this?
I'm writing the same expression for start, end and current m values.
var firstpoint = paths[0][0]["m"];
var lastpoint = paths[0][Count(paths[0])-1]["m"];
var currentpoint = paths
  • ["m"]
    return text(currentpoint)
  • But have no idea what to put in place of the * shown above.
    Is this even the correct approach to using M-values in pop-ups?
    NickHarvey
    Hey thanks for responding Nicholas - No progress sorry to say...Yeah, my guess is that it is not the right approach for retrieving m-values dynamically along the line because our Arcade expressions above each refer to a specific vertex (?).  As my picture above depicts - m-values do show up in the standard popup though (at bottom right)...I wonder about SDK (?)
    XanderBakker
    JosephJordan
    This is FINALLY possible, with the addition of the $userInput profile variable!  Try this:
    var geom=Geometry($feature)
    var densegeom=Densify(geom, 1)
    var PTC=PointToCoordinate(densegeom, $userInput)
    var SegNum=PTC.segmentID
    var paths=densegeom.paths
    var POI = paths[0][SegNum];
    return round(POI.m,4)
    https://www.youtube.com/watch?v=dddZTpsOjY0
    For years I've wanted a way to click a line record in a Web App and extract the Log Mile clicked. (The same way you can in ArcGIS Pro). I've also always wanted to be able to perform dynamic segmentation within web applications. With the arcade geometry functions released this year, this is finally
    KatyLewis
    This is gold!!! Thank you so much. Now users can click along a line and get the nearest m value.
    JosephJordan
    Right??! You bet!  I think ESRI has made experience widgets that work if you have Roads & Highways too....but this is nice because you don't have to click a special widget....can just make the Road ID and M value show in the regular pop up.
    DISIG
    Hello Nick,
    Hello everybody. I am trying to do the same dynamically in Argis Online.(my point geometry change, my m value change in the map context windows)
    I want to use the cut function to get the left length of an intersecting (or nearest) line with M value in a field.
    I will write more after testing all that.
    i have got to 90° rotate the result of a clip between the buffer of my point and the line.
    not easy...
    it quite works...
    récupérer le cumul par intersection du point avec l'arc.
    var CurDep = $feature.ROUTE
    var CurBuffGeom =Extent(Buffer($feature, 2, 'meters'))
    var CurArcGeom = Back(Filter(FeatureSetById($map, /* tests_arcade - Test li */ "17f27378b8d-layer-3"),'route=@CurDep'))
    var CUTTER = rotate(Clip(CurArcGeom,CurBuffGeom),90)
    return LengthGeodetic(first(Cut(CurArcGeom, CUTTER)))
    note : replaced first with back (when i flip the cutter, 90° the left part is the end part of the line.)
