Geographic registration on AutoCAD file.
479
07-27-2017 09:00 AM
chengchao
Why  I  only can do  registration use  two points on AutoCAD file  every time ?
Seven points to determine the location of the map, isn't it?
I chose 14 points to positioning,use  two points every time.
From the first group to the seventh group.Each time  will generate a "WLD" file.
What is "WLD" file about?
Is it only the last two points is work?    The registration of the previous 6 group points  is not action?
How  to  make  geographic  registration  is accurate on AutoCAD file use more than two points?
The question as below attachment picture.
