I use arcgis pro. I'm looking at the census block map shapefile that I downloaded from the census website (area1.png). I would like to compute the geodesic areas of the polygons. The attribute table of the shapefile looks like this (area2.png). I created a new field called "area", right-clicked, clicked "Calculate Geometry", and picked "area (geodesic)" under "property". However, all the entries under the field "area" turned out to be zero. I was wondering whether anyone could help me understand why. Thank you.
What is the current coordinate system of the shapefile? Please share screenshot of the coordinate system and the shapefile's Spatial (XY) extent. Use of an incorrect coordinate system may also cause this issue.
While calculating geometry, what unit are you using for calculating the area?
Check if converting the shapefile to geodatabase feature class helps. https://pro.arcgis.com/en/pro-app/latest/tool-reference/conversion/feature-class-to-feature-class.htm
try Add Geometry Attributes (Data Management)—ArcGIS Pro | Documentation
rather than the shortcut to calculating geometry properties
Hello. Thank you for replying. I tried "Add Geometry Attributes", but still ended up with 0 for the geodesic area when I used the shapefile, and ended up with <Null> for the geodesic area when I used a feature layer in geodatabase. I have tried different units, including square miles, square feet, and square kilometers. The results were the same. I was wondering whether you have any thoughts on this. Thank you.
Hello. I just tried "Add Geometry Attributes" again and it suddenly worked. I don't know why this morning it didn't work for several times but suddenly worked in the afternoon. I didn't change a thing.
Cant blame the Friday glitches at least 😉
