Folder Connections - Wont populate folders on the right
657
10-17-2022 09:59 AM
Sbrewer
Hello Everyone, let me start off saying that I am running on Windows 11 and have been for some time without issue. I am trying to connect a folder so I can grab the data for a project. When I go to connect the folder the right folder view is not visible so I can't select the folder. I have disconnected one drive, did not work, check to make sure the folder is supposed to stay on device, ran ArcGIS Pro as an administrator thinking it could suddenly be an issue. I even made sure to move the folder directly to the C drive document folder to see if that would work but still can't access it. HELP!
I am able to add this picture and do work in other programs.
BarryNorthey
I don't know why it isn't working but as a work around you might try dragging the target folder from File Explorer and dropping it onto BarryNorthey_0-1666199760567.pngin the Catalog pane. Works in Win 10.
n the
