Finish editing line in ArcPro feature moves
2746
04-06-2021 08:58 AM
OwenWhite
Hi all,
When editing a line feature in ArcPro the line moves over and doesn't stay in the same place as saved.
This applies to editing vertices, moving, and creating a new feature. However it only happens when I am snapping to the other line.
Before saving to new location
After saving to location
As you can see it's slightly moved over even though it snapped the first time
Any help would be greatly appreciated,
Thanks!
OwenWhite
Hi Scott,
Thanks for replying so fast.
I was able to remedy the problem by copying the layer and deleting the previous one, that seemed to fix the problem and I was able to go back and make new features/ edit them properly.
Scott_Harris
Hi Owen,
Are the two lines using the same coordinate system? What is the map's coordinate system? Does it match the lines? Are there any transformations being applied in the map?
Does the symbology of the line have an offset effect?
Scott
OwenWhite
Hi Scott,
Scott_Harris
no problem. I'm glad you resolved it 🙂
