Fill in gaps of a column with certain value
2079
08-29-2023 12:39 AM
Lars_H
Hey everybody,
I have a column in the attribute table of my layer that is partially filled with values. I would like to fill the gaps with a separately calculated value. Just to clarify: All the gaps should then be filled with this one value.
Is there a way to do that?
Many thanks in advance.
Lars
RhettZufelt
MVP Notable Contributor
Select the rows to be 'filled', r-click on the column, select Calculate Field and enter the value you want (with quotes if text, no quotes if numeric) and press OK.
R_
RhettZufelt
R_
