Field Calculator - find latest PCI
1266
10-12-2022 12:04 PM
RobertThomson
I'd like to look at the fields pci2016 to pci2020 in each record and find the latest year that has a non zero value, then write that value to pci2021.
Is there something simple I can use Arcade or Python or is this beyond field calculator?
TIA
2 Solutions
JoshuaBixby
MVP Esteemed Contributor
Here is another approach besides using elif blocks:
update(!pci2016!, !pci2017!, !pci2018!, !pci2019!, !pci2020!)
# and code block
def update(pci2016, pci2017, pci2018, pci2019, pci2020):
    for newValue in (pci2020, pci2019, pci2018, pci2017, pci2016):
        if newValue != 0:  break
    return newValue
RobertThomson
This is the first one I tried, worked perfectly.  Thanks to all for responding.
RhettZufelt
MVP Notable Contributor
Field calculator will work.  Something like this should do it.  Of course, you will have to modify to match your data.  I didn't have enough "test" fields.
update(!pci2018!,!pci2019!, !pci2020!, !pci2021!)
# and code block
def update(pci2018,pci2019,pci2020,pci2021):
    newval = None
    if pci2021 !=0:
        newval = pci2021
    elif pci2020 != 0:
        newval = pci2020
    elif pci2019 != 0:
        newval = pci2019
    elif pci2018 != 0:
        newval = pci2018
    if newval != 0:
        return newval
    else:
        return None
R_
JoshuaBixby
# and code block
    return newValue
RobertThomson
DanPatterson
Or a numpy version
import numpy as np
def last(pci2016, pci2017, pci2018, pci2019, pci2020):
    """Do stuff"""
    flds = [pci2016, pci2017, pci2018, pci2019, pci2020]
    whr = np.nonzero(flds)[0][-1]  # first dimension last nonzero
    return flds[whr]
# -- first row in exampe data
last(!pci2016!, !pci2017!, !pci2018!, !pci2019!, !pci2020!)
88
... sort of retired...
RhettZufelt
Or even Arcade:
When($feature.pci2020 != 0, $feature.pci2020,
      $feature.pci2019 != 0, $feature.pci2019,
      $feature.pci2018 !=0, $feature.pci2018,
      $feature.pci2017 != 0, $feature.pci2017,
      $feature.pci2016 !=0, $feature.pci2016, Null)
R_
