I'm wondering if anyone knows why, in ArcGIS Pro, a feature layer shows no value in the AREA field for a polygon feature when the Identify tool is used to see its attributes. But if I add the feature layer to the ArcGIS Pro map at the map service level, as opposed to the layer level, it does show the AREA field values from Identify. Is there some trick to be able to see the AREA field values from either case?
