Feature class to ArcGIS Online (layer + table)
1116
05-11-2022 03:47 AM
Louis-PhilippeTessier
Hello everyone,
My name is Louis-Philippe, I am a mobility project manager working for a Swiss consulting firm and currently working on a GIS project about bicycle parking locations, for which I need your help 🙂
I would like to publish on ArcGIS Online a hosted feature class that has a layer and a table (see images attached below). We have ArcGIS PRO to prepare the feature class.
The goal is to create a webmap visible in FieldMaps that will enable users to click on any point and be redirected to a Survey123 form. We will then link the feature layer and table in order to :
1. Populate the form with existing data;
2. Enable users to fill the form and send the new data in the related table.
I hope this is clear enough, let me know if you need more details.
jcarlson
MVP Esteemed Contributor
In ArcGIS Pro, you can simply create a point layer and standalone table in a file geodatabase, then create a relationship class between the two.
For best results with Survey123, you'll want each layer to have a GlobalID field, and the related table should have a GUID field. Create the relationship class from the point layer GlobalID to the GUID, one-to-many.
Add the point layer and table to a map, then share the service from there.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
Thank you very much for your help, was able to successfully publish my data and it now works on Suvey123!
Have a good day.
