Failed to "update table row". The item was not found.
933
10-16-2017 09:06 AM
MikeSautkulis
I'm trying to edit the attributes of a feature class in a local FGDB in ArcGIS Pro.
I get the following error when typing values into the attribute table directly.
Item was not found.
If I try using the Calculate Field tool I get the following error.
ERROR 999999: Error executing function.
Cannot acquire a lock.
Failed to execute (CalculateField).
However, if I try to perform the same functions on the same feature class in ArcMap there are no errors.
ArcGIS Pro version 2.0.1
ArcGIS Desktop version 10.5.1.7333
Any help would be greatly appreciated.
Mike
